A few Q's on thre SDCE 8-rib Kit...
Old Jan 29, 2005 | 12:51 PM
Ferocity02's Avatar
Question A few Q's on thre SDCE 8-rib Kit...
I am very interested in this kit and it seems that most people who use it like it. So I did a search and got a lot of good info on it , but I still have some quesrions.
1) Can this kit be used with a standard ATI steel 'J' bracket?
2) Do I need to send the bracket into SDCE for them to modify it?
3) Can the SDCE kit be used with an ASP underdrive balancer?
4) I know the SDCE crank pulley can go on the stock balancer, but how is this done when there aren't any mounting mounts or holes on the stock balancer?
5) What happens if I don't have the idler that their site says they need?
6) Anyone have any pics of this setup installed?
Thanks in advance!
Old Jan 29, 2005 | 04:17 PM
frcefed98's Avatar
1)Yep they can use the stock ATI aluminium bracket.
2)Yep SDCE needs the bracket for modification
3)Contact ASP directly for that question
4)Pins, and if I remember right they've redesigned it to work better. I haven't had a problem with my pins.
5)SDCE sends the kit complete you will get all parts needed.
6)Yep, ask NA$TY-TA for pics, i'm pretty sure he has em on his website. I have some but will have to dig em up.
Don't worry about the kit not fitting or working right. SDCE did a great job on this kit and its craftsmanship and the customer service is the best. If you have a problem, scott and wendy will get you through it in no time.
J
Old Jan 30, 2005 | 01:26 AM
osuhunter07's Avatar
sdce rocks
