Supercharger ?'s
Old Jan 29, 2005 | 10:34 PM
GreenHornet37's Avatar
Default Supercharger ?'s
Ok i have a few questions about my supercharger set up(ati procharger D1sc w/sdce 8rib).
1. I am running a Greddy Type RS bov on my car is this bad?
2. I am hearing a surging noise from the supercharger when on the throttle and after i let off what is this? This started after a Fmic install and my bov was put on.
3. Should I upgrade my fuel system? Currently running 42.5 injectors and a 255 walbro pump. I am running 10-12lbs boost on stock cubes motor with Heads (PP lq9 stage 2) and a cam (226/234 598/599 117). I just blew my head gaskets last weekend so I am putting in eagle rods and Diamond pistons 9.3:1 comp while I am in there.
Thanks,
Zach
Old Jan 29, 2005 | 11:30 PM
Grasshopper's Avatar
I can't answer #1 or #3, but on #2, it's because all the excess air is trying to escape back through the blower causing it to surge. Eventually it will ruin your blower. Either your bypass valve isn't large enough, or it's not working correctly.
Old Jan 31, 2005 | 11:59 PM
Well i got into my motor and was hoping for a blown head gasket but unfortunately I cracked the cylinder wall and part of the piston was missing. Since I am only 20 I cannot afford the supercharger and rebuild the motor also. This was my daily driver so I need it back up and running asap. My Supercharger kit will be for sale.
Specs
Ati D1sc~ 18000 mi new seals at 11,000
Sdce 8 rib conversion 10-12 psi
Front mount intercooler
all brackets
42.5 lb injectors
Superchips power programmer with a base tune installed on it
I am lookin to get 4500
Thanks
Zach
Old Feb 2, 2005 | 10:45 AM
Default Price Drop
I am reducing the price to $4000. I need to sell this kit qwik. This includes everything in the kit except the bypass valve and you get injectors and a tune.
