Reliability of the Standard ATI Crank Pulley?
Old Jan 31, 2005 | 04:23 PM
Ferocity02's Avatar
Default Reliability of the Standard ATI Crank Pulley?
I am looking at how this things mounts, and it seems like all that it uses to stay tight on the crank is a bolt, a few pins, and lots of praying. I am talking about the ATI 6-rib crank pulley for the stock balancer. I assume it mounts to the face of the crank, then the three pins "hook" onto the stock balancer to help prevent it from rotating. My question is how reliable is this mounting? Can the pulley actually get pretty well centered with just one bolt? Anyone have one fall off? Is the only fix to pin it to the crank? Thanks
Old Jan 31, 2005 | 09:20 PM
618HAWK's Avatar
Save yourself some time and never ending problems, and go with ATI super dampner and the 8 rib setup. It will out preform the stock setup which you are asking about. Yes I have heard stories of the crank balancer coming loose and departing.
8 rib and ati dampner and pin the dampner to the crank, you wont be sorry.
