Help!!!!!!!!!!!!!!!!!!!!
Old Feb 1, 2005 | 09:49 PM
JerikSS's Avatar
Default Help!!!!!!!!!!!!!!!!!!!!
I need a max effort turbo cam? Where can I get one? What is the best one? Help please I really need one. This is going to be installed with an sts kit.
come on guys help me out
Old Feb 1, 2005 | 10:37 PM
Armageddon's Avatar
...with cheese.
If your going to get a custom grind cam... explain to the company your having do the work what your goals are.
Old Feb 1, 2005 | 11:26 PM
Rick@Synergy's Avatar
When you say max effort, it could mean alot of things. Max for a 346CID or a bigger motor? What is are your goals basicly.
Rick
Old Feb 2, 2005 | 07:38 AM
Ed Potter @ LPE's Avatar
Closed ex-Sponsor Account
Default Turbo cam
Here is a link to to our website, listing our most popular LS1 cams.
You might like our GT-7 cam, which has specs of: 208/230 .554/.546 121
We use it in TT427 setups and make 600RWHP on about 12PSI with an idle that's smoother than stock.
http://www.lingenfelter.com/lingenfe...24&pf%5Fid=102
Let me know if I can answer any questions,
Ed
Old Feb 2, 2005 | 10:33 AM
RealQuick's Avatar
Ed
Ed, the INT/EXH split goes along with the profile of a supercharger cam. Any reason why you guys went that route? Is there an hp/tq difference between your 222/222 (more turbo like in specs) versus the GT-7 one?
Old Feb 2, 2005 | 12:23 PM
Ryan K's Avatar
Pathological Modifier
You can also try Cam Motion, in Baton Rouge, I'd say they make more custom Turbo Cams for the LS1 than anybody. They will ask you a bunch of questions and then reccomend the best cam for your application.
Ryan
Old Feb 2, 2005 | 01:24 PM
1bad2k2ta's Avatar
Whose heads you running? Call and give them your head and internal configuration, where (rpm range) and how much power you want to make. Since they have intimate knowledge of the flow characteristics of their product they can make the most educated recommendation as to what cam specs will perform best for your power requirements.
Good luck,
Tom
