Anyone here rebuilt a P600B before?
Thanks!
Paul
Thanks!
Paul
You can get all the bearings and seals at a bearing shop. I went to one called Purvis Bearing and they had it all. No special tools needed only a press. You have to press the impeller off and on the shaft, other than that it is pretty striaght forward................
So you just took the old bearings and seals with you and they were able to match it all up?
There is a bearing shop right down the street from me. I will give them a hollar before I start dissassembling the unit.
Thanks for the info!
