alcohol + carb + efi
Old Feb 10, 2005 | 11:51 AM
folleyj1's Avatar
Default alcohol injection question
hey guys,
this was just a thought my friend and I had. we were curious about having a carburator that was used as a throttlebody until you wanted to start injecting alcohol. We were thinking that you could get a pressure activated switch that would cut on an alcohol pump for the carb at around 15psi of boost. then the carb would inject the alcohol at a variable rate, and you could compensate by programing the ecu. does anyone have any input?
thanks,
John
Old Feb 11, 2005 | 10:41 PM
folleyj1's Avatar
does anyone have any ideas?....or no who might?
Old Feb 11, 2005 | 10:49 PM
RyanJ's Avatar
SSU Moderator
Why? That's a lot of work vs. just adding two new rails w/ injectors or, more simply, a nozzle or two that inject alcohol into the intake.
