still goin' ...
Old Feb 11, 2005 | 01:46 PM
Noyzee's Avatar
8 second mod
Jam, its looking REAL good!!!!!!!
keep it up. good luck
Old Feb 11, 2005 | 03:51 PM
Got Me SOM's Avatar
very clean install, great job!
Old Feb 11, 2005 | 04:16 PM
JS's Avatar
JS
Thats a work of art......
Old Feb 12, 2005 | 01:55 AM
Jammer's Avatar
Thanks for the props guys. I just spent 3 hours sitting under the car..looking. Thats the probelem..finishing is less exciting than designing. My God.. the oiling is pretty complex. I have dual pumps and dual harnesses with all the goodies and safety buzzers and all that junk. Doesnt look fun... just want to drive it. Its funny... have alot left to do really:
Install LS2 intake... extend map wire, deal with any issues such as the upward angle of the TB (LS2 intake does this).
I want to re-run the fuel line and change the pump/filter configuration (dont like that big blue filter).
Gotta figure out the best way to run long vaccume (perhaps use brake) lines..and thats tricky with the innovative controller and two waste gates.
Change to some stailess brake lines...
Mount oil pumps and run harness and lines
Have exhaust ceramic coated
Lots of lil stuff...
Id guess it'll be, honestly.....another 60 days...this is my busy work season and Im headin to vegas for a week too.
The turbos should not be too laggy... thats why the small housings and A/R's (.63 each) . The wheels were designed with the package...ci, cam,rpm,rear mount, etc. I dont plan to twist her up above 6500 too much so the power should be mid to upper 3's to 6300 ish (RPM wise).
Now...who wants to confirm this... I have to begin by torquing down one head which I had off... I have l-19 studs and an iron block... thats 100lbs right... for these studs???????
Old Feb 12, 2005 | 07:22 AM
Uthinkso's Avatar
Whats your ETA on this project Jay???
Old Feb 12, 2005 | 07:27 AM
PurEvl's Avatar
looks awesome
Old Feb 12, 2005 | 09:11 AM
Jammer's Avatar
If you read the post just above your youi would have seen Nick..... LOL... guessing 60 days. I only tend to get a few hours a week on it... and Im fighting lil buggers in the closet. Your welcome to have Mike come stay at the local motel 6 and finish her up for me.
Old Feb 12, 2005 | 02:19 PM
Uthinkso's Avatar
Worth his weight in platinum.
I still give him that line every now again
Old Feb 12, 2005 | 10:09 PM
jlm44's Avatar
Your My Idol!!!!!!!!
Old Feb 12, 2005 | 10:45 PM
CAT3's Avatar
Restricted User
If you fabbed the return pipes up, running the center of the car, thats fricken awesome, and some exhaust shops need to look at that and get their **** together.
Old Feb 13, 2005 | 01:27 AM
Richiec77's Avatar
That is one awesome install. Are you going to mess around later to see if a "Stepped" Exhaust pipe will help? Something like 2 1/2" to a 2 1/4" or 2" ?
Old Feb 13, 2005 | 08:07 AM
  #32
Jammer's Avatar
Thanks again all. It helps the motivation..which is hard to come by when its ZERO degrees outside.
I do plan to try different combos... most likely 1st mod will be to step to 2" (from 2.5) for the "over the axel" portion.
Old Feb 13, 2005 | 08:26 AM
  #33
Jammer's Avatar
gas line must move..
Old Feb 13, 2005 | 01:47 PM
  #34
blackz93's Avatar
abadss---
did you buy that car from brian pope? it looks real familiar...
jammer---bad *** car man!
Old Feb 13, 2005 | 01:53 PM
  #35
F8L Z71's Avatar
12 Second Truck Club
Are those .68 A/R???
Old Feb 13, 2005 | 03:17 PM
  #36
BIGBOS's Avatar
That is pretty SICK work man.....I love those stock looking tips on there....
No one will ever know
Old Feb 13, 2005 | 08:55 PM
  #37
Jammer's Avatar
Thanks man... just trying to hold the C5/C6 bug away. Nice ride you picked up!
Old Feb 14, 2005 | 10:43 AM
  #38
Camaro_Zach's Avatar
seriously what a slick job. people using one turbo in back manage to make it look like total garbage, but your hiding 2 and doin a great job.
Old Feb 14, 2005 | 11:31 AM
  #39
Green Thunder's Avatar
Jammer..
Awesome job! Man thats looking sweet!
Hey on your Map wiring for the ls2 manifold what are you going to use for a map sensor? I assume you are talking about moving it to the front of the mani where sthe stock LS2 goes..
I am guessing with those bad boys you are going to run a aftermarket 3-bar Map sensor?
Anyway, what I did was tap the stock hole where the Map goes and threaded it then put a plug in it.. Could use it for a vacum/boost port if needed.. Then used a Accel 3-bar off of one of the outlets on the back of the manifold..
Dont know if that will help but just thought I would throw it out there....
Keep up the awesome pics!!
Old Feb 14, 2005 | 12:40 PM
  #40
Arkangel77's Avatar
SO - when will the Jammer Kits be ready for Retail Sales?
