Cam suggestions for d-1sc
Old Feb 13, 2005 | 11:00 PM
redaddiction's Avatar
Default Cam suggestions for d-1sc
I am getting all my parts together for my special setup. I am running a 347 forged shortblock with 6.0 heads. I am looking to push around 10-12 pounds with the procharger. My current cam is a 230/236 on 110 lsa and I dont think that will work very well with the supercharger setup. So any suggestions on a cam ? This is also a manual car.
TIA
Marc
Old Feb 13, 2005 | 11:15 PM
NA$TY-TA's Avatar
I run that exact cam on my setup...... except on a 114+4
Comp XER lobes
230/236 .598/.608 on a 114+4 and im using a 370ci motor......... so in a 347 it will be awsome.
Kyle
Old Feb 13, 2005 | 11:45 PM
Comp XER lobes
Kyle
So you think I should just stick with this cam ? If so should I advance it any ?
Old Feb 14, 2005 | 02:21 PM
white01ss's Avatar
You still need a new cam. Yours is on a 110 lsa, his is on a 114. I believe the 110 will bleed off too much boost.
Old Feb 14, 2005 | 06:39 PM
NA$TY-TA's Avatar
Yes that is exactly what i was saying....... the 110 LSA wont work....... it will bleed of the boost you worked so hard to make.... i was saying go with the same specs with everything except the LSA... switch it to at least a 114.
Kyle
Old Feb 14, 2005 | 08:23 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
hmmm 110 lobe sep, what is that 10 degrees of overlap?
