Launching a Turbo with a TH400
Old Feb 20, 2005 | 12:33 AM
GrannySShifting's Avatar
Hey nick you cna type out dick head here on ls1tech, dont be such a *****!
My personal preference isnt Rossler for converters, but its just my preference
Old Feb 20, 2005 | 01:17 AM
LittleRedZ's Avatar
this is retarded 8 sec car driving from the track and back, i hope you dont have to go far. There is no way you gonna have less then 50k and run 8s
Old Feb 20, 2005 | 03:20 AM
LTLHOMER's Avatar
I know a few people with 8 second cars that would be glad to sell them to ANYONE for 100 grand!
It's expensive to build an 8-second car, but come on folks 100 GRAND. No way.
For 100 grand you can build a super street car. 8 second street car, expect around 30-35 tops not including cost of car.
Old Feb 20, 2005 | 10:32 AM
z98's Avatar
z98
I priced this stuff out and I'm well under the 50,000 mark.
Well please do it.
There are people on this board with 50k in THIER setup and they are running high 9's.
But I don't want to argue with you, as when this post goes away, this will probably never come up again
Old Feb 20, 2005 | 12:34 PM
DAPSUPRSLO's Avatar
I always prefered the ring of D.H. Sound more professional, ha ha.
Old Feb 20, 2005 | 01:41 PM
eviltwins's Avatar
Spoken from someone who has clearly never built a fast car before.
You could easily have 50K wrapped up in a car before you even get down to the motor. Cage work? Suspension work? Chute? Chassis certification? NHRA license? Fire suppression? 25.4/25.5 cage work if you go faster than 8.49? How about the trans, and freshening it once a season? Converter? Rear end? Fuel system?
30-35K tops maybe if you take a light 80's monte carlo, stuff a junk yard 454 in it in front of a home built glide, throw some big slicks and a ton of nitrous at it and hope it doesn't blow up, and end up with a car that runs worth **** on the streets, but to build a heavy forced induction small block car to run into the 8's takes a lot more money than you think. If it was as easy/cheap as you make it out to be, you'd see a LOT more street cars running 8's out there.
Old Feb 20, 2005 | 05:51 PM
LTLHOMER's Avatar
Just because it took you more money than it should have doesn't mean it will take a person who knows how to spend money wisely the same. An 8.9 is an 8-second slip last time I checked and required all of a 10 pt cage to run. I'd like for you to price out everything and get back to me. I've already done it and I know.
Old Feb 20, 2005 | 06:17 PM
eviltwins's Avatar
An 8.9 requires all of a 10-point cage, window net, full SFI fire retardant suit, NHRA license, NHRA certified chassis, SFI balancer, cut off switch, SFI bellhousing, 5-point harnesses etc, etc, etc.
You're right. Stuff a 10 point cage in your stock car, a big motor, and you're ready to run 8's
Old Feb 20, 2005 | 07:39 PM
smokinHawk's Avatar
im pretty sure you can do an 8 sec car for less then $50k, look at the dayton boys did with their 97 formula, almost an 7 second car, and well within less then that
Old Feb 20, 2005 | 08:30 PM
TwnTrboCE's Avatar
It's the "Ohio Boys" and it's a 96.
Don't know about well within. Havn't figured it up and really don't want to.
Should have another one in the 8's as well for less than $50k. In mods that is. Including the price of the car puts me well over.
It can be done but you have to do almost everything yourself and have help from good suppliers.
Old Feb 20, 2005 | 08:53 PM
gnx7's Avatar
I think you need to decide whether your goal of 8's is high 8's or low 8's.... There is quite a bit more money involved to get to the low 8's. Streetable turbo cars can be built that make big power.... but they aren't cheap.
Look at Harlan's car. He doesn't have much in his shortblock (Stock LS1 block/crank, stock main caps, good rods/pistons) $3K?, ported 6.0 heads ($3K?), really nice homebuilt headers (with Burns merge collectors $$$$) $1.5-2K in parts, (2) $900 turbos (approx), Nice intercooler ($1500-2K), BigStuff3 $2.5K, powerglide $1500, Neil Chance convertor $1500+, rear end setup $2.5-3K, fuel system $1500-2K, stuff adds up fast and there is plenty more than that to add up.... I bet he has $35K in mods plus the car thinking conservatively. Real conservatively.
To build a good car with what you want to do you may as well clone what another person has done and avoid the pitfalls they went thru and save $$$ at the same time.
Weight reduction is something you should concentrate on big time. Using a big single turbo will cut down on fabrication work, one less wastegate, less overall weight and overall complexity. It will also be laggier. A set of those out of the box AFR 225's on a stock LS1 block/crank would probably be a good foundation on a budget. Harlan's stock block/crank shortblock has over 30-40 passes on it and still has good oil pressure he said.
Good luck on your build. Wish I had the scribble ($$$).
Old Feb 21, 2005 | 12:54 AM
  #32
LTLHOMER's Avatar
I didn't realize you were counting the window net (100 installed), cut off switch (75 tops) and SFI balancer(200-300). That should bring the total well over 100 grand.
Old Feb 21, 2005 | 09:32 AM
  #33
DAPSUPRSLO's Avatar
Thanks for the input. I have some resources at hand in the form of some knowledgeable people, this board, my tuning ability (although I will learn Big Stuff 3 much like I learned ls1 edit), fabricators, and a shop. Initially high 8s will be the goal but then who knows. I may decide to take the car off the street eventually but right now that will not happen so high 8s is what I'm shooting for now.
Old Feb 21, 2005 | 12:09 PM
  #34
z98's Avatar
z98
I'd guess more like $30k for a solid mid to low 8 second car
Homer, are you talking out of your ***, or do you actually own any fast cars?
I'm sorry, but a bolt on LT1 doesn't give you experience to talk about this stuff to guys who have DONE IT.
Old Feb 22, 2005 | 10:56 AM
  #35
mongse's Avatar
I ruin the end of films...
I've seen a lot of crazy talk in this thread. Over $50K to run 8s!?! I can tell a lot of you don't do your own fab work and installs. Give me $50K and I'll build you a 8-second car.
Old Feb 23, 2005 | 01:11 PM
  #36
z98's Avatar
z98
Where is your 8 second LS1?
That's what I thought.
Old Feb 23, 2005 | 03:05 PM
  #37
mongse's Avatar
Well, I did forget to take into consideration the raping LS1 owners take on parts. I don't have that problem.
Won't see an 8-second slip out of me....that's too fast, I'll get scared.
I think this is officially OT now.
Old Feb 23, 2005 | 04:43 PM
  #38
LTLHOMER's Avatar
I went 12.3's at OVER 115mph! No that's not a mis-print. 115MPH!! That's with only 20 grand into the car! Imagine what i could do with 25 more!
Old Feb 23, 2005 | 05:09 PM
  #39
Mike 01WS6's Avatar
Originally Posted by XJGPN
I can't take posts like this anymore... little things add up REAL quick. I have close to $19K in mods on mine and quite frankly, it is still essentially stock (read, been preparing for FI... but still have yet to actually do anything notable to the long block or actually install any form of FI).... Actually sit down and do the math on all of the little things... The numbers below don't even include all the tools, all the Hardware, all the $$$ in overnight deliveries to get things quick...
Mods:
Motor:
TR224/224/.563/.563/112 Cam $429.99
JWIS Timing Chain $149.99
SLP Manual Fan control switch $69.99
Hypertech 160* Thermostat $48.99
Comp Cams Hi-Tech One-Piece Chromemoly pushrods $132.99
Comp Cams 26918 Conical Spring $159.99
Comp Cams Titanium Retainers $169.99
Cloyes Hex-A-Just Adjustable Timing Gears $149.99
LS1 Camshaft Installation gasket set $58.99
Taylor Thundervolt 50 spark plug wires $69.99
10% Underdriven ATI Superdampener $479.99
NGK TR55-IX Iridium spark plugs $55.92
Direct Flo Lid $125.00
Holley Powershot Airfilter $46.99
Canton Road Race Oil Pan $575.00
Canton Mecca Oil Filter $75.00
Canton Oil Thermostat. $172.50
Setrab Oil Cooler $204.00
APE Ported/Blueprinted/Coated oil pump. $175.00
All of the above plumbed with -12 Aeroquip stainless lines using only Canton and Aeroquip fittings. $250.00
HP Tuners $500.00
New Corvette O2 sensors (don't require extension to work with Long tubes so they are a little more accurate than factory sensors with extensions) $175.00
Exhaust:
Grotyohann 1 3/4" Headers with (2) O2 sensor bungs per collector (for wideband) and V-bolt clamps. $650.00
Custom 3" Y-Pipe with 3-4" Flowmaster collector. Y-pipe Attached using V-bolt Clamps at all connections $500.00
Custom 4" Mufflex performance Mandrel Bent exhaust with Borla XR-1 Racing Muffler. $700.00
Driveline:
Moser 9" Rear axle. 4.10 Gears. 35 spline gun drilled/star flanged axles, spool, aluminum center section, Chris Alstons chassisworks fill plug/drain plug. Spring mounts modified with GC Threaded perches tig welded on. Spohn Control arm re-location brackets Tig Welded on. Painted in POR-15. (Black) $3,000.00
Ram 910 Clutch with 2800lb pressure plate. $459.00
Ram SFI approved billet flywheel $274.99
Mcleod adjustable master cylinder $306.99
GM145 slave cyl $129.99
Pro-5.0 Shifter $179.99
Momo Shift ****. $50.00
Chassis/Suspension:
LG Motorsports Single Adjustable Control Arms $199.00
LG Motorsports Single Adjustable Panhard Rod (trackbar) $179.00
Koni Double Adjustable Shocks (all four corners) $1,199.00
Ground Control Coilovers all four corners (550F/150R) $425.00
1LE Swaybars (front and rear) $275.00
Spohn performance adjustable crossmember mounted torque arm. Heim Joint. $390.00
Fuel System:
Custom Nasty performance Fabricated sumped fuel tank. Custom built to my specs (To give additional clearance for 4" Exhaust and Ford 9" Axle when lowered) using a fuel safe 2 1/2" filler inlet (standard is 1 1/4" bung without rollover protection, this gives the safety of a rollover protection valve and larger tube to allow for faster re-fueling.) (2) -8 (rollover protection check valved) Vent lines plumbed with Aeroquip hose to outside of framerail with K&N Breathers. $850.00
Fuel Safe Aircraft Style Remote Mount Flush Cap to allow use of 2 1/2" Fill Tube $173.75
Brakes:
Earls Stainless Brake lines $119.95
Hawk HPS Pads $151.98
Thunder Racing Line Lock Kit $215.00
SLP Weld on Sub frame connectors - Tig Welded $229.95
Wheels/Tires:
Nitto 555R2 tires (P275/40/ZR17) $500.00
Extreme Motorsports Chrome Z06 Wheels (17x9.5" all around) $1,299.80
Blizzaks on stock Chrome wheels. $500.00
Interior:
Speed Inc. Lightweight Carpet (Brand new, haven't installed it yet) $269.99
Autometer Quick Lite $168.97
Exterior:
Factory Camaro SS hood. $1,200.00
Total: $18,872.65
After seeing this list, and the way you spend your money, it's no wonder a fast car is going to cost 50k+ for you. I can see many things where I would have gone a different route, and some other things that are only going to slow your car down, and/or not contribute to racing at the strip at all.
You spend money like a trailer park lottery winner.................on stupid, useless ****.
