Turbo Cam Questions?
Old Feb 20, 2005 | 08:54 PM
PewterWSSicc's Avatar
Default Turbo Cam Questions?
Well i have decided that i am definately going to be going with a turbo, probably phamspeed single or twin. But its a little ways away. Probably towards the end of the summer and race season. So to make my car a bit faster i wanna do a cam. So here are some questions about doing a turbo cam.
1. Whats a good size turbo cam to do?
2. About how much rwhp gain could i be looking at with it stock?
3. On low boost 8-10psi how much does a turbo cam help?
Any other pertinent information would be greatly appreciated, thank you.
Old Feb 20, 2005 | 09:02 PM
qqwqeqwrqwqtq's Avatar
What are your goals for-
Horsepower
Driveability
My personal preference is to run fairly small cams with turbo setups, because a big cam is not neccessary to make ALOT of HP.
Old Feb 20, 2005 | 09:32 PM
My goals are mostly just to make some more power while i wait to get the turbo. And then be ready for the turbo with a cam installed for it already. My power goals with the turbo are to make some where around 550rwhp, 550rwtq on 8-10lbs and meth injection, if i need the methanol. Also will ofcourse have an A/A FMIC on the turbo. But prior to that i need to get my rear-end and tranny. thats why i am just looking for a cam for it for now. Any cam should make more pwoer than the stock one.
Old Feb 21, 2005 | 05:50 AM
smokinHawk's Avatar
you can do that easy with a stock cam, but if you want some power while you wait a 220 to 226 duration cam with a 114 lsa would work
probably with a reverse or equal split
