? About Using Brake Booster Line for Boost Guage
Old Feb 20, 2005 | 11:48 PM
Ferocity02's Avatar
Question ? About Using Brake Booster Line for Boost Guage
I read that this is the best place to install the boost gauge. For this location, do you use a mechanical or electrical gauge, or either?
Old Feb 21, 2005 | 01:04 AM
Boostaholic's Avatar
Electrical gauges use manual sending units.
Old Feb 21, 2005 | 01:15 AM
Ferocity02's Avatar
That doesnt really answer my question... I guess what you are saying is that I might as well be using a mechanical gauge? I know some people who stick to mechanical and other who prefer the simplicity of electric gauges...
Old Feb 21, 2005 | 01:33 AM
Your question was mechanical or electical, what I said was all gauges are mechanical at some point.
I personally think that mechanical guages are better, one less thing to go wrong. I will be running mechanical oil press and boost, fuel press will have a electronic sending unit because of track regulations.
Old Feb 21, 2005 | 01:42 AM
Ferocity02's Avatar
If one were to run a mechanical vac/boost gauge, would the line running from the brake booster line to the gauge need to be short to give accurate measurements, as in running it straight through the firewall under the booster as opposed to running it all the way through the passenger side grommet in the firewall?
Thanks for the help
