SDCE + Dual spal fan Help!
Old Feb 24, 2005 | 09:27 PM
WS-6_2002's Avatar
Default SDCE + Dual spal fan Help!
Anyone with this set up? I am putting mine in and seem to be having some clearance issues with the tensioner and the fan motor. Anyone else have this problem? Does SDCE know of this problem?
Old Feb 25, 2005 | 01:14 AM
Blackbird's Avatar
scoot the fans over towards the passenger side and you will have to dremel down part of the plastic on the fan assembly. when you look at it, it will be obvious what to grind down.
Old Feb 25, 2005 | 06:57 AM
JIMMYZZ28's Avatar
Spals dual fan set up is pretty thick you could always go with a custom shroud and their slim line fans......
Old Feb 25, 2005 | 10:13 PM
WS-6_2002's Avatar
Blackbird
Do you have any pics? I tried to move the fan all over the place and couldn't get it right. Where is your fan sitting? If I move it to the passanger side and put the fan in fromthe bottom the blower hits the fan motor. I cut some of the plasitic and the support fins holding the fan motor too. If I go from the top the SDCE tensioner hits the fan motor.
JimmyZZ28
I think the dual fans are thier slim line.
I also tried to trim as much of the fan's plastic shroud as I could. I just need about 1/4 of an inch more and I could slide it in.
Old Feb 25, 2005 | 10:17 PM
Blackbird's Avatar
oh I know what your not doing. just remembered.
lift the radiator up and pop it out of the mounts, (on the bottom of the radiator there are rubber mounts that sit in holes) you can then push the bottom of the radiator forward and gain the space you need.
Old Feb 25, 2005 | 10:48 PM
2000silverbullet's Avatar
Do those fans work?
Old Feb 26, 2005 | 12:47 AM
WS-6_2002's Avatar
Blackbird
Do I have to put the rubber pieces back after? I'll give it a shot tomorrow. Sounds like it'll work. Did you have the fans mounted more on the top side or bottom?
2000Silver Bullet
I'm not sure yet haven't got them running. Only heard good things though.
Old Feb 26, 2005 | 01:46 AM
Ferocity02's Avatar
Where does one get dual fans for a Procharger set-up?
Old Feb 26, 2005 | 03:09 AM
CAT3's Avatar
Restricted User
Myles, there you go, why wait til tomorrow when you can knock it out tonight! Good luck, will be nice to get back and hear that beast and ya gotta take me for a ride.
Old Feb 26, 2005 | 07:36 PM
WS-6_2002's Avatar
Ferocity02
I gotmine from YOGI's. They were the cheapest I found and they usually have one in stock.
CAT3
I had to. I have drill this weekend.
Old Feb 26, 2005 | 09:24 PM
Blackbird's Avatar
you dont remove the rubber pieces.
you will see when you do it. just lift up on the radiator and they will pop out of the holes they sit in and then push the radiator forward.
Old Feb 26, 2005 | 10:33 PM
PRAY HRD's Avatar
i have a set of dual 11" spals/be cool, and if i remember correctly they are about 1/2" thinner than stock. so i'm not sure where your clearance issues are.
Dave
Old Feb 26, 2005 | 11:02 PM
WS-6_2002's Avatar
Well just an update. Took the rubber pieces out. Gaveme more clearance but just a little short. Need to grind down the back of the fan motor a little. I think it might JUST fit we'll see tomorrow. Rain came out to play and stopped the progress.
Clearance is with the SDCE tensioner kit for an ATI supercharger.
Old Feb 27, 2005 | 11:02 PM
WS-6_2002's Avatar
Blackbird
Got it in, but how close is your fan to the tensioner bolt. Mine is resting on it. I know there is some play in the radiator and fan. I just hope that it doesn't chaff.
Old Feb 28, 2005 | 10:38 AM
JIMMYZZ28's Avatar
Default slim line fans
I have two pics of the slim line spal fans but i do not know how to insert them. I am also unable to host them here. The low profile fans are 2" thick vs. 3.25" and 4.25" dual assembly. Let me know if anyone is interested in view these. We can make shrouds any depth you need.
Old Feb 28, 2005 | 11:04 AM
Blackbird's Avatar
I dont have my setup any longer but if I remember correctly it did touch or was within 1/16th of doing so.
