Lots of Boost Stock Displacement?
Old Feb 25, 2005 | 02:08 PM
blackbelt's Avatar
Default Lots of Boost Stock Displacement?
Ok here is the ?
I have done some research and yes I have used the search. But I want to know how to get a 347 to handle 16 to 18lbs of boost.
I am planning on building 346/347(what ever it comes out to be) Here is my goal. 750 to 800 to the ground with alky injec. Here are a few ?'s
1. Will stock crank hold that much power. I I have it is good to 1000rwhp but can some people give me some examples of people doing it.
2. Will alum block with stock sleevs(machined of course) hold 16lbs? Will the cylinder walls stand up to that kind of pressure and how reliably?
3.Will 205 AFR O ringed be my best bet?
4. I head about bigger ARP studs will that be needed? more info please.
5.Will I need billet main caps?
Sorry for all the ?'s but need to find out for sure before i start building it. Any suggestions as far as 347 build up are appreciated.
Old Feb 25, 2005 | 02:59 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
1. Will stock crank hold that much power. I have heard it is good to 1000rwhp but can some people give me some examples of people doing it.
<----752rwhp, T400
Yes
AFR's sound good, not sure if everyone would agree about o-ringing
I would get really good head studs
No
smokinHawk's Avatar
the stock block can easily hold 800rwhp provided its tuned well.
crank will hold around 1500 horses for at least one season, y2khawk here ran several 170mph passes with the stock crank, and it didnt break
id just used the stock sleaves if your only wanting 800, it has been done alot.
the afr 205's will be a good choice with their thick deck height
i djust use an mls gasket and forget the oringing
you can get away with the standard arp head studs or go with a super strong arp stud
stock caps will be fine, billet arnt needed
Old Feb 25, 2005 | 03:06 PM
Boostaholic's Avatar
What compression ratio do you plan to build it at? That is a big consideration for a motor like what your planning.
Old Feb 25, 2005 | 03:07 PM
y2khawk's Avatar
1. Yes
2. Yes
3. Dunno yet, 6.0L heads here
4. No
5. No
All answers based on my experience on my setup
8.29@167, 8.52@171 3350 lbs
Old Feb 26, 2005 | 12:37 AM
NA$TY-TA's Avatar
Originally Posted by y2khawk
1. Yes
2. Yes
4. No
5. No
show off......
Kyle
Old Feb 26, 2005 | 01:19 AM
blackbelt's Avatar
Probably like 9:1 or so Should it be any lower?
Old Feb 26, 2005 | 08:06 AM
y2khawk's Avatar
Originally Posted by NA$TY-TA
show off......
Kyle
he asked
 Michael S. Palmer
Old Feb 26, 2005 | 11:55 AM
eviltwins's Avatar
If you run a bit lower compression, and a bit bigger motor you should be able to make 750 to the ground without having to rely on alcohol injection. Don't buy into what everyone says about losing low end if you go lower than 9:1 comp, because it just isn't true.
Old Feb 26, 2005 | 12:04 PM
blackbelt's Avatar
Motor will probably end up being around a 370 or so Iron block. I want this sucker to stay together! So what compression should I shoot for? Also Any recomendations on fuel system set ups. Its a 01 ZO6.
Old Feb 26, 2005 | 01:06 PM
sb427f-car's Avatar
SSU'S Vice Mod
The LS1 block will hold no problem, are you that concered with the block? Are you going all bore? If you are go with an LS2 block and save yourself the weight and the worry about boring into the H2O jackets. 8.6:1 is always a good blower ratio, alot of roots cars seem to use that and they run fine.
Old Feb 26, 2005 | 01:21 PM
LS1Tech Co-Founder
I don't think Matt ever hit a dyno, but I bet on a Dynojet he would have done over 950rwhp to hit his mph. Very impressive. Matt went that fast without o-ringing anything and with 6.0 MLS GM head gaskets. Stock diameter head studs, no 1/2" studs. I've been impressed for a long time that he did so much without exotic solutions for the gaskets and head studs. His tune may have been a touch fatter than others and that may have made a difference if he wants to comment.
I'm doing 752rwhp, t400, A1 head studs, 6.0 MLS head gaskets (followed Matt), and 21.5 psi. At this point I would need to pulley down or go cog to hit higher power levels. My YSi-Trim is equivalent to a 78mm single turbo setup. But I'd have to go to a really small blower pulley. But I'm just saying that there is more in it. Stock displacement has a lot of potential. For an all out drag I would go LS2 stock bore block + forged crank that is around stock.
Old Feb 26, 2005 | 02:06 PM
qqwqeqwrqwqtq's Avatar
I think Harlans car would -probably- be more like 1200+rwhp
Old Feb 26, 2005 | 02:26 PM
NA$TY-TA's Avatar
on a stock PCM........... with his own tuning..... if his ET's werent impressive enough already...... i know Matt... Now that you have sponsors whens the new buildup starting.
FYI im 8.87:1 370 iron block and going for 800+ to the wheels with a PTE-88.
Kyle
Old Feb 26, 2005 | 02:28 PM
Earl H's Avatar
'03 Z06 Single Turbo (T76GTS)
Mild Port LS6 Heads
ARP Head Studs
9.25 Compression
14 PSI
Alchy Injection
730RWHP/740RWTQ
Was running 16psi to get those numbers. After cam change, same numbers achieved on 14psi.
Old Feb 26, 2005 | 02:53 PM
NA$TY-TA's Avatar
Mild Port LS6 Heads
ARP Head Studs
9.25 Compression
14 PSI
Alchy Injection
730RWHP/740RWTQ
Earl ... time to change the sig buddy...... says coming to a 2004 boosted list near you....... and were in 05 now
Kyle
Old Feb 27, 2005 | 02:00 AM
blackbelt's Avatar
I would love an LS2 block but not quite sure if i like the whole knock sensors situation. Any solution yet? So LS2 block should hold 16 to 20lbs(if i start want more ) Also HOw much does O ringing cost? I would rather have too much safety than not enough.
Also the general consensus is I just need regular ARP head studs?
Old Feb 27, 2005 | 01:09 PM
LS1Tech Co-Founder
What cam change Early, sounds interesting.
Jim, I'm thinking Harlan was 1000-1050rwhp but that's just me (Dynojet 248). I think he did hit a Eddy dyno once and if he saw over 1000 on there well then it was... more on a 248. Either it's extremely impressive.
Old Feb 27, 2005 | 02:20 PM
Earl H's Avatar
Cammotion custom turbo grind. Prior to the new cam, I ran the MTI B1, which I think was more of a mild N/A or SC cam.
Old Feb 27, 2005 | 05:13 PM
99Fbody99's Avatar
First 950..then 1050...what are you new?
To go 170mph at 3400ish it take 1250-1300hp to the tires.
Take a look at your old mph and and weight and plug into any decent calculator an be enlightened
Dave
Blackbelt,
If you going boosted I would stick with a stock block and crank with a good set or rods and pistons. Its been done a ton of time and is the most cost effective and reliable way to do it. Boost level will be 16ish depending on your power adder. the GM MLS gaskets are more than capable of holding that level of boost.
