? about 8 rib crank pulley with double roller timing chain
Old Feb 25, 2005 | 03:18 PM
98TXFBODY's Avatar
From: Used to live in South Texas, Now in North Carolina
Default ? about 8 rib crank pulley with double roller timing chain
Couldn't find anything with a seach...
Bout to put the D1SC with the 8 rib set up on my dads 427 vette. Anyway it has a rollmaster double chain which can't use the stock crank pulley b/c the oil pump is spaced out to clear the timing chain. Will the pulley that comes with this kit work with a double roller chain?
Thanks
Old Feb 28, 2005 | 06:46 AM
98TXFBODY's Avatar
anyone know?
Old Feb 28, 2005 | 09:19 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I am running a Rollermaster dual chain along with the ATI superdamper 8-rib pulley. Works just fine
Keith
Old Feb 28, 2005 | 01:55 PM
snkchrmr's Avatar
I am having the same issue. i talked to ATI about there damper but they wasn't for sure so I called a well known company that builds LS1's (I want say their name b\c I'm not sure they are a sponsor) they said they face the back part of the snout off .070 of an inch. Hopefully it's not to late for me I have put about 600 miles on mine with stock pulley .
Old Feb 28, 2005 | 05:38 PM
JR-CRUZN-C5's Avatar
I run an ATI/Cloyes Double Roller/8 Rib setup with no problems!!!!!!!!!!!!
JR
