FMIC Question
Old Mar 7, 2005 | 02:45 PM
Juiced's Avatar
Default FMIC Question
How would i calculate Intercooler efficiency and sizing for my car?
It i'll be a 370CI Iorn Block with 16PSI boost.
Old Mar 7, 2005 | 03:43 PM
mongse's Avatar
I ruin the end of films...
http://www.bellintercoolers.com/Pages/tech.asp#I
You'll probably need a rough idea on hp numbers and the amount of room you have to work with to size the intercooler. Also whether it's A/A or A/W.
Old Mar 7, 2005 | 04:02 PM
Juiced's Avatar
Cool thanks fo rthe Info. So if i'm shooting for about 750rwhp through an m6 what would be the size intercooler that i would need
Old Mar 7, 2005 | 04:29 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Using what, a turbo? What size?
Old Mar 7, 2005 | 04:31 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Like John said, we need more info...
Old Mar 7, 2005 | 04:37 PM
Juiced's Avatar
I'll be doing the GT-42 or PTC-t76gts depending on availability when FAb work and motor is done. It will be going into a corvette so i need outlet to face upwards.
Old Mar 9, 2005 | 06:45 AM
JIMMYZZ28's Avatar
One of the most important things to consider when selecting an intercooler is how much space do you have for the unit. The intercooler with the a broader core face has more efficency then on that would be thicker and smaller. Alot of people are unable to run a large thin intercooler due to space issues but, need it to flow cfm in the masses. That when the designs usually get thicker and the efficiency drops off due to residuel heat passing through the thicker core. There is always a trade off......
