D1SC pulley change
Thanks!
Dave
assuming the car is already in the air
Disconnect the intercooler y from the discharge of the headunit.
Disconnect the inlet hat(air filter box)
Release tension on the s/c belt by loosening the jamnut on top of the bracket, back the top bolt out until all tension is off the s/c belt.
Slip belt off crank pulley.
Get a set of allen head sockets, use a 5/16 and a 11/32 if I remember right(reason I always had the full set next to me, I can never remember the other size
Take out all allen head bolts from the s/c-bracket combo(they are attaching the s/c to the bracket)
Pull blower down.
Now get your favorite impact ratchet, hold the s/c in your lap with the impeller blades facing down(be sure not to damage them) and not on the ground!!! Hold the s/c pulley as hard as you can with gloved hands, have a helper take the bolt thats holding the s/c pulley on. Now the s/c pulley will either slide off with a gentle pull or be stuck on.
If its stuck pretty good, get a pulley puller(med size 3 jaw puller) put a socket of the same or a lil smaller on the shaft of the s/c as not to damage it, and use the puller
to pull the pulley off, be careful and take your time.
I think thats all of it, be sure to use a dab of threadlock when installing the bolt into the s/c shaft.
J
Thanks again for the info!
