STS installers PCV question
as you know STS provides that little solinoid thingee or whatever it is to put in line with the pcv line that goes to the TB and I assume it must slam shut under boost to prevent pressurizing the crankcase but I am still wondering what you guys are doing.
my initial thought is to take the line they have you put back into the TB and run it into a catch can and then to the atmosphere and cap off the connection on the TB.
lets hear what you guys think.
thanks!
On our LT1 we run a catch can vent system which is at 14psi right now, and on the LS1 the STS PCV system which has worked fine for us up to 13psi through a FMIC. The catch can check valve system would work fine too on an LS1. Preference.
