need help with heads and cam w/ t-63
Old Mar 19, 2005 | 07:33 PM
destroyerSS's Avatar
Default need help with heads and cam w/ t-63
we are fixing a true hack job from another shop and the owner would like to have his motor done correct this time. Here's whats done so far
383 CI
9.0-1 comp Diamond turbo pistons
6.125 eagle rods
Callies racemaster 4.000 crank
LS1 motorsport turbo set up with a T-63 turbo
cam is INT 218 564 EX 213 540 and a 116 LSA
So my ? is what would the BEST HEADS to run with this set up and should we also go to a larger cam?? Thanks
Old Mar 19, 2005 | 07:50 PM
Got Me SOM's Avatar
I would go with the AFR 225's. On paper that cam looks like a good turbo cam to me. You might want to go up in duration since its a 383.
Old Mar 19, 2005 | 08:58 PM
i'm not sure if the customer will spend the money for AFR's. Any other options? what CC heads should be used?
Old Mar 20, 2005 | 08:17 AM
T T T
Old Mar 20, 2005 | 02:38 PM
does anyone have any experience with this t-63 turbo???
Old Mar 20, 2005 | 03:27 PM
MIGHTYMOUSE's Avatar
i coud not make more than 523rwhp on a built 346 with that turbo and set up. you are better off getting another turbo set up if you want any results to be happy about.
Old Mar 21, 2005 | 09:11 AM
smokinHawk's Avatar
a 383 with a logged T63 turbo = the yuck.
for heads you could do some 6.0's a affordable solution
