How to trigger fuel pump?
Old Mar 27, 2005 | 12:18 AM
355ss's Avatar
Default How to trigger fuel pump?
I have 3 options on how to trigger my aeromotive pump on to high speed. #1 The first option was to use an output from the dfi that will be triggered off of RPM. #2 Or use a hobbs switch on the manifold to sense boost. #3 Or use a hobbs switch on the fuel rail. I am leaning towards option #1 anyone else have an opinion.
Old Mar 27, 2005 | 01:20 AM
Boostaholic's Avatar
Your using Gen7 for engine managment? I would let Gen7 trigger it if thats the case.
Old Mar 27, 2005 | 03:05 AM
MelloYellow's Avatar
I found an MSD RPM Switch worked much better than the Hobbs. More consistent tune also. My 2nd Walbro only turns on at 3800rpm+.
You want the single pill switch, not a window 2 pill version.
Old Mar 27, 2005 | 07:39 AM
DaveSchott's Avatar
For a turbo I'd go with the boost sensor as it is quite possible for a turbo to make little boost at higher rpm. RPM would probably work great with a positive displacement s/c.
Old Mar 27, 2005 | 08:32 AM
355ss's Avatar
forgot to mention it is m112 but it is on a 3rd gen
