Compressor surge?
Old Mar 29, 2005 | 09:08 AM
TurboZ28's Avatar
Default Compressor surge?
Simple question, what is it exactly? In laymans terms if possible.
Old Mar 29, 2005 | 09:09 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
In laymans terms, more air being produced by the turbo then can be consumed by the engine.
Old Mar 29, 2005 | 09:20 AM
TurboZ28's Avatar
I'm assuming this is bad. Does that damage the turbo? and how?
Old Mar 29, 2005 | 09:26 AM
LS1TECH Sponsor
Yes its bad. Its jars/wears the bearings...which is not a good thing.
Jose
Old Mar 29, 2005 | 09:31 AM
TurboZ28's Avatar
Thanks Jose
Old Mar 29, 2005 | 09:32 AM
furiouSS99's Avatar
Quotes from (2) different turbo info sources:
"Compressor surge: You can think or surge as the point at which the compressor blades begin to “slip” in the air, losing their pumping ability, much like an aircraft wing loses its lift when it stalls. In a turbo, this happens in a series of bursts, as the blades slip, then bite, slip then bite. This sets up a pulsing wave in the turbo piping and explains why the sound has that characteristic “flutter”. "
-Source:GoFastBits
"Surge is an instantaneous reversal of airflow that occurs as boost increases at a fixed airflow"
-Source:Gale Banks
Old Mar 29, 2005 | 09:39 AM
LS1TECH Sponsor
Compressor surge rarely sounds like flutter, surging you will know by the rpms of the car rising and falling in a rythmic cycle. Our Supra's do this with the larger head units if they aren't optioned with ported shrouds or anti-surge compressor covers.
Jose
