Add an intercooler = how much more psi?
Old Apr 1, 2005 | 01:09 PM
jsniper's Avatar
Default Add an intercooler = how much more psi?
I have a 99 camaro SS which is pretty much stock except it is a 382 stroker with a forged crank and pistons which have 9:1 compression. I also have an aftermarket fuel pump and 60lb injectors. The car is using an STS kit and runs good at 11psi with the methanol turned on. I upped the boost to 14psi and the car ran much worse than it did at 11psi. As stated, I have the methanol injection but I do not have an intercooler. I am assuming that 14psi is too much boost and creating too much heat which is causing knock and the ECU is retarding the timing. Does this sound right? I do have a FMIC (large 3" OBX) now and will be installing it on Saturday. Since I now have an intercooler, should I not worry about using the methanol anymore and can I run 14psi or is that still too much?
Old Apr 1, 2005 | 01:28 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default Meth
If the meth is already there leave it. It will only have more benefits than draw backs.
Old Apr 1, 2005 | 03:10 PM
NumberOneSled's Avatar
Are you running stock heads/cam in that 382?
Old Apr 1, 2005 | 05:52 PM
F8L Z71's Avatar
12 Second Truck Club
Sometimes it's better to keep the psi the same but run more timing.
Old Apr 1, 2005 | 07:31 PM
gogogadgetcar's Avatar
which turbo are you running? It might not be up to the task of giving a 382 14 psi
I would think water/meth injection would be better than most air/air intercoolers
