Procharger Experts help! Belt problems.
This is very stressful, i had the car running fine since i bought it, which is like 8-9 months ago, no squeeking whatsoever, and it just started doing it, and it wont go away. Do you think replacing the blower belt would take care of it?
BTW the squeek only occurs at idle.
If you want a permanent solution look to SDCE. Spring loaded setup do not have as much strain on parts like bearings. But you're going from $40 for two new tensioner bearings to $600+ for a new pully setup. Just FYI.
Mike
Mike
I wouldnt wanna do the $600, if the new tensioners can last me another 20k miles, its fine. Can i order theseparts online or do i have to call procharger. thanks.
Mike
All this info is in this forum...us ATI guys have been through this and then some..I rec' getting the SDCE set up ASAP or you will be replacing belts and bearings faster than you will like and that starts to ADD up. Especially if you are trying to get a certain boost level which is damn near impossible with the stock ATI pulley set up and its belt slipping problems. Do a search you will see how troublesome this is.
J
