Boost change with stroker?
Old Apr 16, 2005 | 11:10 PM
Moz's Avatar
Moz
Default Boost change with stroker?
Last week took my car out of storage and the crank pulley had come loose and was walking on my crank shaft . So now the motor has to come out and i will be putting in forged crank stroker kit probely a 3.900" stroke kit.Before this situation happened i was running 8.5 lbs of boost. With me stroking the motor will this change my boost levels any? Also how much more boost could i add to the stock block and still be safe with a new dyno tune.
Please any input would be greatly appreciated.
BTW , the new crank will be double keyed and the pistons will most likely be dished
Old Apr 17, 2005 | 09:48 AM
Moz's Avatar
Moz
Someone must have stroked a blown LS1?
Old Apr 17, 2005 | 05:45 PM
Moz's Avatar
Moz
Anyone?
Old Apr 17, 2005 | 05:46 PM
sb427f-car's Avatar
SSU'S Vice Mod
It shouldn't change the boost as you aren't changing really any of the restricting points in the motor, ie, exhaust or intake.
Old Apr 17, 2005 | 06:02 PM
My84Z's Avatar
Since your not changeing the heads and exhaust or anything but the bottom end I would say you aren't gonna loose much if any. I'd say a half pound depending on how low compression you go. also the stock block can hadle quite a bit of power with the right internals so boost away! 16+ pounds
Old Apr 17, 2005 | 08:53 PM
2001WS6Vert's Avatar
You'll probably loose a couple lbs. The only reference I have is that with a g-trim Vortech and the 2.75 pulley on a 418 I could only muster 5 lbs. (I think some have made 9+ lbs. with that combo on a 346). I had this combo on for a short while until I switched to the T-trim and made 12 lbs.
Old Apr 17, 2005 | 09:25 PM
whitt1's Avatar
You will lose some boost.Going from a 5.3 to a 402 my truck lost about 4 1/2 lb. of boost.You won't lose that much,but you will lose 2 to 3lb of boost.
