Adapting Whipple kit to LS1
Here's my idea. The Whipple kit for the 4.8L, 5.3L and 6L Vortec Family is cheap and from reading the directions.. Very easy to install. 3900 Bucks complete from superchargeronline. It doesn't sit ontop or replace the existing intake manifold. It mounts to the left side of the engine.. See Below..
Whipple's kit also comes with some sort of fuel computer which could just be deleted and a Dyno tune with 42# injectors/LPE Fuel Pump could be added. I've e-mailed whipple for more info and exact mesurements of the kit so see if it will fit in the C5's engine bay. I'll keep you updated.
But if you want to run the truck superchargers, all your belts will not line up. The trucks use a different balancer, and water pump.
Also the kit your speaking off, mounts up ALOT higher than all the f-body vette kits. Hell, the manifold replacement type supercharger, requires you to put a cowl hood on the vette's There isn't a whole lot of clearnace much higher than the decorative corvette fuel rail covers. The alternator is about as high as you can go under the hood of the vete's for sure.
The f-body may give you a little more room but not much because the windshield cowl covers 1/4 -1/3 of the engine. The truck supercharger is pretty long and would need to get under that wiper cowl to fit.
How much of a difference is the LQ9 Belts position to the LS1's? Could that problem be fixed by running a longer snout on the Whipple?
I have the Caravaggio blower hood coming which would give me alittle more clearance. We'll see.. I would love to attempt this but if it's not worth it.. I'll stick with the Maggie until Kenne Bell comes out with there twin screw.
Could you snap some high detail pics of the mounting? I'm curious to see how far the blower sits compared to the valve covers and Coil's.
EDIT - I was looking at your site. Would it be possible to make a custom adapter so i could bolt-on a Whipple 2300AX inplace of the Heaton in the Maggie kit? If so.. How much would that run me?
www.starrperformance.com.au
warren
warren
LQ9 Kit only costs 3900.
Heavy.. Is there anyway you can take some measurements for me?
I also recieved info from whipple this afternoon. They have never tried to fab it up to an LS1 so this should be fun. They ofcourse said that they'll be there with any questions.
If it doesn't work.. I'll just throw it up on Ebay
or the 3300ax
Stick it in your engine bay and see if it will fit. Best way to find out
