Help please.
Old Apr 24, 2005 | 04:09 PM
JZ'sTA's Avatar
Default Help please.
Well, after yesterday's events at Bradenton (sucky time slip, car felt like crap) I decided to take the car out today and do some logging so I could adjust my PCM fuel trims at part throttle, then move on to full throttle again.
I found that when I get the car up to around 4500-5000RPM at part throttle (about 20% to 30%) the car just falls on its face. It's like it hits a brick wall and doesn't want to go any higher. I have to give it quite a bit more throttle to increase the RPMs. Happens in gears 1 2 and 3, didn't try the other gears, but at least that shows (hopefully) it's not a drivetrain thing.
The RPM it hits at changes, it seems like at lighter throttle I can get it to hit at around 5000, at heavier throttle it hits earlier.
Would valve float, related to bad springs maybe manifest itself this way?
Car is a 383 stroker with 9.0 compression, Turbo kit, heads cam etc.
Plugs seem fine, and I gaped them correctly.
Not a boost leak because I am only at part throttle.
Thanks
Old Apr 24, 2005 | 07:02 PM
METAL MAN's Avatar
You need to check your fuel pressure while your driving. Tape a gauge to the windshield and have someone watch the pressure when you go WOT. The pressure shouldn't drop at all, if you have a boost referenced regulator it should go up with boost. I'd say this is probably your problem. If you don't have at least a Walbro 255 your long over due.
Old Apr 24, 2005 | 07:03 PM
METAL MAN's Avatar
One more thing, make sure that plug gap is tight, you'll want to be around the low .30's and not over .37.
Old Apr 24, 2005 | 10:01 PM
JZ'sTA's Avatar
Thanks Metal MAn, however the problem is at part throttle.
Fuel is there, and the plugs are gaped at 0.30.
Old Apr 24, 2005 | 10:56 PM
Armageddon's Avatar
...with cheese.
is the car showing any other symptoms?
