TTP Stage I Magnum...........
Old Apr 24, 2005 | 08:12 PM
BLKICE690's Avatar
Default TTP Stage I Magnum...........
Want a new motor, and I'm wanna go with TTP Stage I Magnum....I want to know if its a good motor to boost on. Any recommendations would be greatly appreciated.
Old Apr 25, 2005 | 10:12 AM
TTPMatt's Avatar
It would be good for boost in the 8-10 lb range. When you want to run a ton more I would be looking for a forged crank.
- Matt
Old Apr 25, 2005 | 10:52 AM
RyanJ's Avatar
SSU Moderator
What a salesman...
The stock crank has been pushed past 25lbs of boost and over 1000rw...not that boost level actually determines anything.
Old Apr 25, 2005 | 11:30 AM
TTPMatt's Avatar
Ryan: You're correct about the boost level not determining it but its a good factor to consider most people running 15lbs are in the 700+ range. Yes the stock crank has been pushed far, but I wouldn't take that chance. Yes the forged crank is a lot more $$, but you won't be blowing it up.
- Matt
