valve cover breather?
I also added a catchcan between the valvecover and the blower intake pipe.
Under boost some oil (blowby) goes back to the intake: the blower will just spray it into the intake. Not too bad but you'll never know if a blower seal is gone or if it's just the PCV system.
The catchcan is put in this way so that the oil will go back to the crankcase after being retained in the can.
I tried a breather (easier than my blowby catchcan) but it messes up the LTFT. At low-middle RPM the engine will see unmetered air and will run lean. In my case the lower cells went from -2 to +10.
