PCM to run Turbo
Old May 11, 2005 | 04:51 PM
tomulrich's Avatar
Default PCM to run Turbo
What are you guys using to control you turbo set ups? Are there any problems with the 98 PCM....Can a 98 support 2 or 3 bar with HP tuners or EFIlive, LS1 edit?????
Please post as much info as possible.
Old May 11, 2005 | 04:59 PM
MECHAM's Avatar
98s dont support 2-3 bar with hp tuners..eflive..etc...etc....
we are the bastard children....
Old May 12, 2005 | 07:31 AM
libertine1015's Avatar
What are you looking for? I think a good tuner like Speed Inc. can get 750ish from a stock PCM with the right set up. If you want to go higher than that then the $2300 you will spend on BS3 or equivalent is peanuts compared to what the rest of the set up will cost. just my $.02
