Problem with Procharger install (vacuum line)
Old May 14, 2005 | 12:47 PM
KajonZ's Avatar
Default Problem with Procharger install (vacuum line)
I am at the tail end of a Procharger install but I am having trouble with the vacuum line supplied by ATI. It isn't long enough to reach from the inlet hat to the vacuum source. I am also not sure which line to run the hose to.....Not sure If I have to buy more hose, any suggestions?
Old May 14, 2005 | 02:39 PM
furiouSS99's Avatar
The only line that runs from the inlet hat is the one to the passenger side valve cover-and it was more than long enough...is that what you are talking about?
Old May 15, 2005 | 12:23 PM
Floader's Avatar
I think he must be talking about the line for the bypass valve. Since I removed the AIR system all I did was take out the check valve on the back of the intake and pluged it in there, the line was just long enough for that.
