What Ring Gap for FI motor?
Old May 14, 2005 | 02:36 PM
Arkangel77's Avatar
Default What Ring Gap for FI motor?
WHat ring Gaps are you guys running on your motor's? I am rebuilding a 8.5 to 1 LT1 that will see about 16lbs of boost with an Intrcooler and rear mount system. Just looking for recomendations so help me out, Please. Thanks, Lata, Ark
Old May 14, 2005 | 03:14 PM
69firebird's Avatar
Here is what Mahle reccomends
.055xbore=gap
that is for forced induction, however most use a larger gap, closer to a .065 to calculate. And Kurt at W2W is saying to have the first ring gapped to what you want (ie use formula) and then add some to the second ring to make it a bit larger.
does this make any sense, I sure hope so
Old May 14, 2005 | 05:40 PM
Arkangel77's Avatar
Yep I think I got it ! WOW that seems off!
If its a 4.0" bore times .055 that = 0.22 which seems not right? Did I mess that up? How Much More should the 2nd ring be than the first?
Set me streight if I am off? Thanks, Lata, Ark
Old May 14, 2005 | 06:35 PM
99Fbody99's Avatar
.0215" top ring
.025" on second
its
bore x .0055" top ring
bore x .0065" second ring
Dave
Old May 14, 2005 | 07:27 PM
Arkangel77's Avatar
OK - I see. my first set of rings was gaped at .035" - I guess they were not too tight now were they?
Old May 14, 2005 | 07:30 PM
KAOS's Avatar
what about gapless rings? anybody using them with lsx's
Old May 14, 2005 | 09:17 PM
Nate_Taufer's Avatar
I usually see guys running them on engines with gas ports but not usually on FI motors, just High compression no power adders.
