Dyno'd the STS on 11 psi T67
My uncorrected numbers were like 460 hp (damn vegas heat and altitude!)
I'll have to post the graphs when I get home. The graph looks bad though, it's very wavy with the smoothing on 5. It did this last time too, some have suggested a possible ignition problem, timing curves are pretty smooth.
I also have to fix an exhaust leak which is affecting my spool up.
Dynojet 248C. Unfortunately it did not have the load cell option which suck when you want to dyno a turbo car.
i bet the car is making more than that on the street. so make sure to dial the A/F in at least a full point richer on the dyno. IE 11:1 if you want 12:1 on the street.
either the cam is really killing you or you have more tuning to go. you should be well into the mid / upper 500's on 11psi IMO.
Warm vs cool weather dyno in vegas on a turbo/supercharger car shows about a 35-50 rwhp gain/loss with no other changeds, it's bad. I still think my dyno is a little on the low side for the amount of boost.
I'm not sure if the cam hurts or not, it's got zero overlap. I'll be changing it when ever i decide to build another motor.
Nate
We have the new Dynojet 224XLC with load cell and are only a few hours away from you in Vegas. I have dyno tested many turbo cars and the load cell makes them come up in boost MUCH faster and they usually make more power to the roller when we load them first then make the pull. Let me know if you would like to schedule an appointment anytime.
-Bryan
-Bryan
We have many many dyno's in vegas, I think we are up to 10 public dyno's now
I really wanna dyno on a mustang dyno. I might do that this weekend if I get my exhaust leak fixed. I can live with my (500+ rwhp) numbers for now. Car is tons of fun to drive
I had a 50/50 mix of 91 and 100 in the tank, timing was 13 at tq peak and 19 by redline.
