homemade alky/meth injection
Old May 24, 2005 | 10:32 AM
fletchls1's Avatar
Default homemade alky/meth injection
I have been reading about these all over the place...how is it done?
Old May 24, 2005 | 01:16 PM
3800SII's Avatar
Use a 12 volt pump, a relay, Water solenoid or check valve, brass spray nozzle, and some hoses, clamps, and a Hobbs pressure switch. Do a search and you will find that you can set one up for less than $100 bucks total.
Old May 24, 2005 | 02:37 PM
fletchls1's Avatar
not bad...are they worth it....im going non intercooled
Old May 24, 2005 | 04:01 PM
tici's Avatar
I see 100F drop with 8GPH 50% ethanol. This on a non intercooled 6PSI Vortech.
AFR 12.5 and 22* of timing, no KR. In my sign it was with 11 AFR without alkyl.
Next week I'll have a dyno session and I'll post the new numbers.
Setup: see my homepage - it's 100% homemade.
Old May 25, 2005 | 02:10 AM
studentdriver's Avatar
That's really impressive cooling! Eliminating knock with that much timing and a relatively lean AFR is very nice.
