Best stroker for D1??
Old May 27, 2005 | 12:57 PM
oOoLy's Avatar
Default Best stroker for D1??
I want to run procharger D1 in my C5 2000 but i want to get the best stroker 347 or 383 or iron block ?
I need your advice to choose the best one .... !!
Thanks
Old May 27, 2005 | 01:08 PM
2000 Tran Zam's Avatar
im sure youve heard the old saying "theres no replacement for displacement"
however, what are your power goals, and what is your financial situation
Old May 27, 2005 | 03:57 PM
oOoLy's Avatar
I need the most power from the engine ...
Old May 27, 2005 | 07:57 PM
wiht more stroke and displacement, you have more cubes to fuel your setup. just think of it logically. even if you ran NA, you would make just for example 400 rwhp on setup X, while with a 383, youd make 450 rwhp on setup X due to the cubes. its pretty much a no brainer, if you can afford it, do it.
Old May 27, 2005 | 10:35 PM
Uthinkso's Avatar
My opinion while it wasn't an option above would be a 370 in either Iron or LS2 configuration.
