Help me guyssssssssss
Old May 28, 2005 | 12:21 AM
hold's Avatar
Default Help me guyssssssssss
HI
I have vorteh supercharger V2 SQ for LS1, I have just the unit i need to ask about the's think i need't for PONTIAC GTO 2004
Cast aluminum mounting bracket mounts power steering pump and supercharger
Anodized billet mounting plate assembly relocates alternator and spring tensioner
Bosch compressor bypass valve
Molded inlet duct retains stock air box/ MAF location
Welded charge air cooler core assembly with aluminum discharge tube, Bosch compressor bypass valve, silicone sleeves and stainless steel hose clamps
Charge air cooler water storage tank with hoses, clamps and plumbing
Compact water circulation pump for closed loop cooling
Water cooler
Fuel system upgrade includes 42 lb/hr fuel injectors
Oil drain and oil feed assemblies allow for maintenance free operation
Old May 28, 2005 | 12:57 AM
PREDATOR-Z's Avatar
You need to post this in the FI section
And BTW you spell GUYS like this; not Gays. Which country are you from??
blacktransam's Avatar
forced induction forum is down a few
