fuel pressure question
Old May 28, 2005 | 03:47 PM
SINISTER's Avatar
Default fuel pressure question
hey guys ready to start this bad boy up!!
need a question on where to set the fuel pressure i have my set just like nasty's
like dis
https://ls1tech.com/forums/showthrea...light=spangler
im running two walbror in tanks with all the love -8 line all the way up intoi my speed inc fuel rails feeding 60 lbs motron injectors....and my stock feed as my return line..
my question how many lbs of fuel should i have the guage reading?
i have a good base tuen from speed i just need to run it around no real boost to just check everything is a ok with no leaks....then it goes to speed for the full dyno tune...
nasty
mightymouse and suggestions?
running 6.0 iron block all forged low cr 6.0 heads
t-76 single turbo
thanks guys
Old May 28, 2005 | 11:00 PM
SINISTER's Avatar
12 views and no love
anyone lend a hand in this?
Old May 29, 2005 | 11:11 AM
SINISTER's Avatar
now where at 24 views no one has a clue???
Old May 29, 2005 | 11:32 AM
JMBLOWNWS6's Avatar
I know mine runs at 60 PSI. Thats with a racetronix pump.
Old May 29, 2005 | 12:10 PM
ChevyNo1's Avatar
Mine is set @ 48 at idle since it's boost referenced. Pull the reference off and it's right around 60.
- Dug
Old May 29, 2005 | 03:09 PM
SINISTER's Avatar
- Dug
cool mine is a sx engineering boost refernce one..
so i will go with these numbers!
thanks!
Old May 30, 2005 | 01:59 AM
ChevyNo1's Avatar
No problem!
