Ls1 turbos in 1st gen
I'm looking for something fairly ballsy with somewhere north of 500rwhp, however I don't want the power very much below 4k rpm for better driveability
Essentially my question is what else will I have to do/use.
-Turbo cam (which would have a nice idle)
-bigger injectors (how big)
-turbos (what would be good for specs?)
-custom make some headers (what size primaries wall thickness and material?)
-lots of tubing with 45* and 90* bends (ditto)
-wastegates (if not integral what size)
-blow off valve (what size)
-air to air intercoolers
-wide band O2
-reprogrammed ecu
-downpipe
Things im not sure about
-different intake, maf, throttle body?
-dropped compresion pistons
-clutch
-trans
etc
I'm sure im missing tons of stuff in there so please let me know, im under the impression that the bottom end can take quite a beating, but since the motor will be out of a donor car is there something else i should do before dropping it in.
sounds like a fun project. Good luck!
Okay now gotta stop thinkin abt the car and get ready 4 prom...
