supercharger gurus step in-->
Old Jun 6, 2005 | 02:22 PM
whitecamaross's Avatar
Default supercharger gurus step in-->
i wanted to know how much rwhp can i expect with a procharger kit (base kit) on a bone stock 04 z06 if everything remains the same?(stock exhaust, stock internals..etc) is it possible to hit say may be 500rwhp tuned properly?
Old Jun 6, 2005 | 02:31 PM
mdhmi's Avatar
Which ProCharger kit? The P-1SC or the D-1SC? If you have not already purchased the kit I would *highly* recommend that you look into either an ECS or A&A ProCharger setup.
500 rwhp is very doable with stock hardware.
Mark
Old Jun 6, 2005 | 02:39 PM
Grasshopper's Avatar
A shop here locally made 535rwhp on an '02 Z06 with ATI's new Stage II kit, with nothing else done to the car other than a fuel pump.
Old Jun 6, 2005 | 02:46 PM
i was looking at the A&A corvette supercharger kit.
Old Jun 6, 2005 | 02:48 PM
NoGo's Avatar
500 HP on near 11:1 compression is a cinch to do. It only takes a couple pounds of boost (around 6 psi on a Z06).
Just make sure the tune is VERY conservative due to the high static compression of the motor. Alot of people have popped stock Z06's with low/moderate boost.
Old Jun 6, 2005 | 02:54 PM
PurEvl's Avatar
what nogo said...make sure its very safe tune but 500 is easy on a z06, esp with an a&a kit
