Anyone tried an INTRACOOLER
Old Jun 10, 2005 | 08:40 PM
kitronic's Avatar
Default Anyone tried an INTRACOOLER
Check out this website; http://www.coolflow.com/
Click on:Refrigerated Chillers & Intercoolers
He sells air to refridgerant intracoolers for some cars and will work with you on custom applications. This solves some of the space/location problems associated with standard intercoolers.
Another "cool" effect is you can run your AC on the racetrack. The power increase is far more than the loss from the AC compressor.
Old Jun 10, 2005 | 10:06 PM
spun03cobra's Avatar
Most ac compressor's clutch disengages when at wot. How would this help?
Old Jun 10, 2005 | 11:17 PM
parish8's Avatar
single digit dreamer
the ac does shut off during a run, it doesn't actualy make power in real time, it chills the water before the run and then uses the cold water during the run.
i think it is a great idea but probably not worth the cost or complexity or added weight. prety sure a 50shot would give you more power than this set up and cost a whole lot less or put that $2500 toward heads and get the extra hp that way.
Old Jun 10, 2005 | 11:53 PM
99SS-T's Avatar
i believe that this is something that they are planing on doing with the next gen lightning. Sounds rea cool if they can bring the price down for 2500-25000. That is alot of dough for anything let alone a intercooler.
John
Old Jun 11, 2005 | 01:05 AM
I agree with you 100%, I have a gt42 on my camaro and your gonna bet your life I'm spraying that bitch out in this hot *** heat.
Old Jun 11, 2005 | 10:29 AM
30th TA 0219's Avatar
John
That idea was killed long ago (The Lightning overall, but tha CA thing was a gimmick)
It was said to provide a 20hp boost for like up to 10 seconds. HARDLY WORTH THE TROUBLE AND EXPENSE
Old Jun 11, 2005 | 10:54 AM
unit213's Avatar
Administrator
spun03Cobra - max sig pic size is 500x150. Please reduce yours. Thanks.
