Injector Size for Vortec Supercharger
Old Jun 11, 2005 | 12:36 PM
TRANSAMWS6-98's Avatar
Default Injector Size for Vortec Supercharger
What size injectors should I purchase. I have heads, cam and all bolt ons.
Old Jun 11, 2005 | 12:52 PM
narcszm's Avatar
anything from 39-45 lb/hr will work. Depends on how much flywheel HP you're making and how easy you want to tune.
Old Jun 11, 2005 | 01:46 PM
mdhmi's Avatar
Which head unit? How much boost? How power power are you shooting for? The 42 #'s seem to be fine up until around 550 at the tires. I had 42 #'s with my D-1SC ProCharger setup and they worked fine. I decided to use 60 # injectors for the TT buildup, although I won't need them until I turn up the boost.
Mark
Old Jun 11, 2005 | 03:03 PM
Inspector12's Avatar
TT-TECH Veteran
I have MSD 55's that are good for 600 I know maybe more. Look RC engineering and they haven a calculator on thier website that gives you the size you neeed based on the info you imput IE: Displacement, Desired HP, Fuel presure etc... Everybody seems to like the Motron 60's. The 38's that come with the kit are good for about 500 give or take a few hp depending on tuning and desired outcome.
