Heads:casting #873
Old Jun 13, 2005 | 03:11 PM
Scary Guy's Avatar
Default Heads:casting #873
Would these heads be any good to use on a FI motor?
Thank You,
Mark
Old Jun 14, 2005 | 12:40 PM
ktmrider's Avatar
Thank You,
Mark
Not familiar with those, could they possibly be #853? If so they are OK, but no different flow wise than the #241 ( 853 has perimeter cover bolts ).
Old Jun 14, 2005 | 02:26 PM
Scary Guy's Avatar
They are #873.They are LQ9 iron heads off of a 2000 6.0 motor.Supposed to be just like the #317 aluminum.
Mark
Old Jun 14, 2005 | 03:40 PM
ktmrider's Avatar
Sorry about that! Learn something new each day....
My info shows the #873 iron head with the same specs as the #317 aluminum. They flow the same as the #243 LS6 heads with bigger chambers ( 72cc ).
Great fit for F/I vehicles, should lower compression for more boost. Only down side is the iron design, makes detonation more possible.
Look in the LS1/LS6 Internal engine thread for a sticky at the top ( CC vs CR I think ) for a better idea on your CR with the 72cc chambers.
Old Jun 14, 2005 | 08:28 PM
Scary Guy's Avatar
ktmrider,
Thanks for the info,i learned something too.lol
Mark
