Wastegate?
Old Jun 17, 2005 | 12:36 AM
SuperZ's Avatar
Default Wastegate?
Say you are running at 38mm wategate with a 12 pound spring with no boost controller will the car run right at 12 psi.Will it be steady boost or will it jump around.Thanx.
Old Jun 17, 2005 | 01:22 AM
99SS-T's Avatar
You have to hook a vaccum line up to it but yes it will be a perfect 12 psi as long as the turbo doesnt overpower the wastegate. I dont know sizes on wastegates but if 12 is the lowest that the spring i dont know of many turbos that will force the boost higher. GL man
John
Old Jun 17, 2005 | 02:15 AM
KissMySSo1's Avatar
A 38mm gate is kinda small. To small for a V8 in my mind. But depending on the power of the car it will work. If you have a 12lb spring in the gate it should hit 12psi and stick there like glue untill you let off.
