compression ratio and it's effect
The farther you drop CR, the more boost and flow the blower has to provide, which the belt has to support. Bigger head units and better belt setups cost money.
I'm running 8.65:1CR, a D1SC, 3.2" 8-rib Reichard pulley, and hit near 14psi. But the blower doesn't like spinning that fast and boost starts dropping above 5,500rpm until it hits 10psi at 6,500rpm. I just dyno'd yesterday and I'm at 570rwhp/560rwtq. I called procharger, and they're recommending I upgrade to an F-1 head unit.
Did you ever run at lower boost and that compression ratio? If so, what were your dyno numbers like?
I push 16 psi and 700 RWHP @ 8.2:1 compression. If you are using the stock ATI intercoolers, that is your problem, not the blower head unit.
Is that with a D-1SC-1? I have an early A&A FMIC (wide and thin) but their latest full wrap bracket and 8-rib pulleys. If motor X makes 400 HP at 5 psi on 10:1 compression it would likely make 400 HP at 6 psi on 8.5:1 compression. Especially when we're dealing with 350 cubic inch motors, the dramatic low end power losses associated with dropping compression are greatly overemphasized on here, IMHO. For a street motor 8.5:1 compression is a nice healthy range. I would never build a 9.5:1 street blower motor, you just can't run as much boost as I would like to.
Is that with a D-1SC-1? I have an early A&A FMIC (wide and thin) but their latest full wrap bracket and 8-rib pulleys.The Best V8 Stories One Small Block at Time
Is that with a D-1SC-1? I have an early A&A FMIC (wide and thin) but their latest full wrap bracket and 8-rib pulleys.Mine's not a freak either. A maxed D1 should bring 600+ RWHP no problem at all.
Boost > Compression
Had I not had a direct before/after though, I wouldn't have been able to tell.
One story that I always tell the folks that buy into this low-compression drivability problem. We had a 99 Mustang cobra come in one day with a fully built motor. We strapped it to the dyno and laid down a wopping 220 HP. The car ran great though. After a couple calcs we had figured out that the motor had inadvertantly been built with 7:1 compression. You would never been able to tell though. The car ran and drove fine. His power loss was an utter mystery until we started to ask the guy about the details of his build.
Maybe on a no-torque flat 4 you'll feel a difference, but all of the V8's that we have dropped the compression on the effects were little to none.
