need help measuring my twin turbos.
Old Jun 20, 2005 | 09:08 PM
osuhunter07's Avatar
Default need help measuring my twin turbos.
Hey, So i got the twin turbos finally from auctane 71 or jonathan hendrix after a long dispute. here is my qeustion though, they are the t04b housings and when i measure I get
Inducer 2.167
exducer 2.951
Not sure of the make of these they are supposed to be t60s but using the formula
(inducer/ exducer)2 *100 I get 53.9
To these are t54's? am i correct in doing this. I measured from tip to tip on the most forward "fin" the indcuer same for the exducer
Old Jun 20, 2005 | 09:14 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Yes, that specs out to be a 54mm turbo. Those are definitely not T60's. Also measure out the exhaust side, we can find out what wheel it is. More then likely its a stage 5 or T350. Which okay for a mild buildup, but for big power, thats a no no.
Jose
Old Jun 20, 2005 | 09:29 PM
2.2 and 2.5
Old Jun 20, 2005 | 09:32 PM
I can get more Exact measurements if need, those are with the dial but not down to the .000, if need be let me know. Thanks so much Jose
Old Jun 20, 2005 | 09:57 PM
LS1TECH Sponsor
The exhaust side is a T31. That is a tiny wheel and actually smaller then a T350. Those turbos will cause excessive backpressure if you plan on making any real hp.
Jose
Old Jun 21, 2005 | 06:18 AM
turbo-max's Avatar
Originally Posted by osuhunter07
2.2 and 2.5
t-3 stage 3 on those turbine measurements
Old Jun 21, 2005 | 06:20 AM
turbo-max's Avatar
Inducer 2.167
exducer 2.951
closest i get is for a TO4b 54 trim in =2.170 ex = 2.950 flow rate = 45 #'s /min
