how important is heat in a turbo setup? (hot side, not compressor side)
But looking at the success people are having with STS rear mounted turbos, I am wondering... how big of a factor is this heat?
Is it worth putting the turbo up front in the engine compartment... and ceramic coating the headers and hot pipes?
Harlan is right on this. the STS setups work well but if you notice, most of those turbos run smaller ARs to compensate for the slower velocity of exhaust @ that point in the system and the lower EGT by that point. Hotter gas moves faster and thus helps maintain efficency in the turbine. Don't get me wrong, there are some people that have the remote mounts figured out, but to make big power, up front still seems the more prefered method.
Absofuckinglutely. Inlet charge energy is the key to getting the most out of your turbo system. The higher the inlet temperature the higher the efficiency you will be able to obtain on your turbo. Higher efficiency means less parasitic loss and more power to your wheels
STS systems will work, but will run at a hampered turbo efficiency. You can get an STS to make what a front mount will, but it will take more boost, longer to spool, and you won't get the rated HP out of the turbo/compressor setup.
Jose
Any other tips on how to manage heat/temperatures on the hot side? ie coatings, positioning, anything?
