Trying to wire up boost controller...help!!!!
Old Jun 26, 2005 | 04:25 PM
anarchy99's Avatar
Default Trying to wire up boost controller...help!!!!
Need some help finding certain wires on the back of the ECU. Here's a picture of the wires I need, but the diagram is from an import... Any help on where these wires are on a 00' Trans am would be Super helpful!!!!
File Type: doc
Old Jun 27, 2005 | 11:38 AM
anarchy99's Avatar
t t t......
Old Jun 27, 2005 | 11:51 AM
onfire's Avatar
Coal Mining Director
My Apexi is on a 99 so the wires are different, but I can save you some time. You only need to take the tps,rpm and speed to the ecm....find a 2000 service manual and it will reference which wires to tap into.
Tape the two ground wires together and hook them to a ground under the dash. Go to the main controller connecter that has the 11 wires and go down about 12 inches from the connector and you will find the y junction with two red wires that join to the red wire in the connector. Pull the one back through the sleeve that goes to the ecm and connect it to a keyed source under the dash.....makes it easier.
Old Jun 27, 2005 | 06:20 PM
anarchy99's Avatar
That was the biggest help man... your my hero!!!!!!!
