will my head and cam setup work on a supercharger
Old Jun 30, 2005 | 09:16 AM
cgworth's Avatar
Default will my head and cam setup work on a supercharger
i was thinking of buy a supercharger and was wondering if my current head/cam setup woulf work with it i have a TSP228 cam and ported and polished ls1 heads that are milled .36
Old Jun 30, 2005 | 09:37 AM
01Blackerado's Avatar
It really depends on the CR your at right now.
Old Jun 30, 2005 | 09:46 AM
cgworth's Avatar
i think it was 10.8 to 1
Old Jun 30, 2005 | 09:54 AM
Thats a little on the higher side you really want to be around 10:1 or lower. I'd check around a little bit more before you take 100% from me though. Some people might have been able to get it to work with it that high, but I'm not sure. I do know that most people that have blown there engine, usually have 9.5:1 or lower!!
Old Jun 30, 2005 | 09:58 AM
cgworth's Avatar
my next question is if its ok to use that comp ratio then how much boost is safe on it?
Old Jun 30, 2005 | 10:02 AM
I know it wouldnt be much, but you could probably squeez out anywhere from 8-12psi if tuned and fueled properly. Then again I'm not 100% sure on the higher side number
Old Jun 30, 2005 | 11:39 AM
Ed Blown Vert's Avatar
Its high. I was able to run 5-6# on 11:1 and pump gas. Timing was 17*
