at what rpm does the boost build in a sts setup?
Old Jul 3, 2005 | 08:55 PM
buck2769's Avatar
Default at what rpm does the boost build in a sts setup?
Just like the title says. I also would like to know if this is only at WOT or will this build just cruising around and/or maintaining rpm? I have never owned a forced induction car before so I'm not really familiar with characteristics of the turbo.
Old Jul 4, 2005 | 12:15 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
There are too many variables to really answer your question. There are standard and gt trim turbos, standard and ball bearings, different housing sizes and ratios, and totally different size turbos. And the engine makes a big difference too- displacement, cam, intake, etc. I almost forgot- manual or automatic trans and if auto, what stall converter. Sorry, just no simple way to answer you question. Depending on the combo, boost could happen anywhere from off-idle (great), to over redline, in which case you would never spool up.
Old Jul 4, 2005 | 07:33 AM
buck2769's Avatar
The size of the turbo and all it's other related factors is the same as the default from the sts kit without a turbo upgrade. The size of the engine is the stock size of a ls1. Stock cam. And the trans would be a stick in this case. I am really looking for an answer from an owner of an STS kit. Someone with first hand experience not someone with theoretical knowledge.
Old Jul 4, 2005 | 04:08 PM
trtturbo's Avatar
normally on my 6 speed car, it is at full boost by 3100 and starts around 2500 or so. This is assuming you are taking off in 1st and nail it.
Old Jul 4, 2005 | 05:43 PM
reocamaro's Avatar
Even in my messed up auto I hit 4 lbs of boost at around 3300, and then it shifts and I hit 5 lbs of boost in 3rd by 3500. And for me I only hit max boost that early at WOT.
Old Jul 5, 2005 | 12:10 PM
menlatin's Avatar
^^ is that with the .84 A/R turbine housing?
Old Jul 6, 2005 | 08:37 AM
boosted99camaro's Avatar
my car with 6 speed I see full boost at 3000 or so if im just crusing a say 2000 rpm and slowly get into it I see some boost a 2500 and max boost 8# at 3000-3300
