Vacuum Source for D1SC Bypass Valve\Boost Gauge
Old Jul 5, 2005 | 11:10 AM
sschmid's Avatar
Question Vacuum Source for D1SC Bypass Valve\Boost Gauge
I have recently installed a D1SC kit on my 02 SS. It came with the typical 4" pulley. I was only getting about 3 lbs boost, so I went to a 3.6". Now I am getting a little over 5. I live at 4500 feet, so you can expect lower boost numbers than at sea level. I am curious if my vacuum source is good enough and if the bypass valve is opening all the way? Where is the best source to pull the vacuum? I am currently pulling it off the line to the brake booster... Any help would be greatly appreciated...
Old Jul 5, 2005 | 11:51 AM
anarchy99's Avatar
Ihokked my boost gauge up to the brake booster also. Works great!!!
Old Jul 5, 2005 | 12:00 PM
kp's Avatar
kp
Brake booster works fine, your boost seems a little low but it depends on whats done to the motor and you are at pretty high elevation..
Old Jul 5, 2005 | 12:13 PM
sschmid's Avatar
Good to know, I will leave it running off the brake booster line... I agree about the low boost numbers, I am hoping it is elevation... The motor is stock, just lt's, injectors, fuel pump...
Old Jul 5, 2005 | 12:20 PM
kp's Avatar
kp
Its probbaly about right with headers and your elevation, you can drop to a 3.4 but belt slippage starts to come into play. Also depends how high you turn it, I always ran my stock motor ATI car to 64-6500 rpm so you see a little more up there.
Old Jul 5, 2005 | 01:51 PM
WAHUSKER's Avatar
Can you still use the brake booster hose if you have a vacuum modulator hooked up to it already?
Old Jul 5, 2005 | 08:44 PM
Ferocity02's Avatar
Brake booster here too.
FYI... I am making only 4.75psi with a 3.6 pulley, at sea level....
