GT42 Turbo set up almost done.........:)
Old Jul 10, 2005 | 10:01 PM
spun03cobra's Avatar
Default GT42 Turbo set up almost done.........:)
Here are some of the originals....
Cant wait till it's done!
Old Jul 10, 2005 | 10:08 PM
frcefed98's Avatar
Nice glad its coming together. What type of oil drain are you running for your GT42?
J
Old Jul 10, 2005 | 10:14 PM
69firebird's Avatar
do you have any more pictures of the setup?
Old Jul 10, 2005 | 10:24 PM
J
I'm running a -4 feed, -10 return.
Any hp guess's on what it will make, it's a 241 stock headed stock cube ls1 with a comp cam .228 .236 .588- .601 on 114. I was think of somehwere in the lines of 12-15#'s with race gas.
Old Jul 10, 2005 | 10:59 PM
Any advise on a good boost controller?
Old Jul 10, 2005 | 11:19 PM
frcefed98's Avatar
Turbosmart boost controller thats listed on the GP by Jose.
Looks to be the one to get. I have the lowly dual stage turbosmart boost controller 12psi low boost and 18psi high boost for my two stages.
Is your oil return higher than the pan with the turbo placed right there, or do you have an oil pump on the return line? I was having some drain back issues with mine just a lil above the crank pulley. I had to restrict the oil line. I still get a puff of oil smoke when I have to stop hard or when I beat the car a lil.
Old Jul 11, 2005 | 12:32 AM
NA$TY-TA's Avatar
Looks good man... more pics.... LOL
Jer,
I think im going to run the same BC as you. One setting for street use and one on KILL for the track. I have other things i need before i spend $400+ on a elec BC.
Kyle
Old Jul 11, 2005 | 12:51 AM
Being an electronic boost controller how would it know what gear the car is in if I want to leave, I have a turbo 350? Also I was just thinking of running a manual boost controller inside the car, kinda like an air line press controller. Thank you for your help guy's.
Old Jul 11, 2005 | 09:40 AM
RealQuick's Avatar
Looks like the kit MetalMan was making...I am interested on how the system will react with the turbo mounted to the chassis. I know there are flex sections...post results when you get it running!
Old Jul 11, 2005 | 11:39 AM
smokinHawk's Avatar
how does the intercooler go?
i see it has two inlets merging into the trottle body, but looks like a single intercooler and turbo set up?
Old Jul 11, 2005 | 11:54 AM
red90cobra's Avatar
exactly what i was wondering
Old Jul 11, 2005 | 03:32 PM
The intercooler has a single inlet with dual outlets, inlet is on the drivers side and the outlets are on the top. Yes it is also the kit metal man is doing.
Old Jul 19, 2005 | 05:57 AM
I want to drive my car!
Old Jul 19, 2005 | 11:46 AM
2000 Tran Zam's Avatar
So whats left on it to finish up?
Old Jul 19, 2005 | 12:39 PM
Armageddon's Avatar
...with cheese.
thats pretty neat looking
Old Jul 19, 2005 | 03:01 PM
Sandmann120's Avatar
Why two outlets?
