Intercooler charge pipe size
Old Jul 11, 2005 | 09:50 PM
crazy2one's Avatar
Default Intercooler charge pipe size
I just got part of my Phamspeed kit today and I was told that the intercooler pipe size would be 3". Well after measuring it's only 2.5". My question is how bad will this hurt the system as a whole. I will be running a T76GTS and I'm shooting for 700rwhp on pump gas with an iron 370.
Old Jul 12, 2005 | 12:53 AM
KissMySSo1's Avatar
It will be fine
Old Jul 12, 2005 | 05:42 AM
smokinHawk's Avatar
the 76gts discharge is 3"
so you'll be steping down to a 2.5" then later back up to the 4" opening at the TB, not the best, but 2.5 will get you by.
if you want to gain every bit you can then run 3" to the IC then have the IC opening be 4" to the TB
Old Jul 12, 2005 | 06:33 AM
KraZy's Avatar
I would try and contact him, and see if he will correct the mistake.
Old Jul 16, 2005 | 06:20 PM
crazy2one's Avatar
Ok I contacted phamspeed and they said that 2.5 will support 1000HP, while this may be true I was under the impression that it will cause me to boost more for the same HP compaired to the 3" as well as putting more heat in the charge. Another thing the pipe is made from mild steel which is going to rust will the rusting of the pipe on the inside cause me any issues I don't want rust chips in my motor.
Old Jul 16, 2005 | 06:42 PM
69firebird's Avatar
The rusting thing shouldnt be that big of a deal, there will be some condensation on the inside, however if they used aluminized piping, that should eliminate most of the rusting problems.
I agree with smokin, I would use 3" to the IC, and then 4" from the IC to the TB, that is what I plan to do, and I have the same kit that you do. Phamspeed, with T-76GTSH.
